Jacob & Co. Astronomia Régulateur
From another launch event from Watches & Wonders 2024 in Geneva this week, Jacob & Co. unveiled often the Astronomia Régulateur. Historically employed by watchmakers eager to regulate their particular work, the régulateur is well known for its ultra-precise accuracy in addition to unique separate dials exhibiting hours, minutes and mere seconds. high quality fake watches
Jacob & Co’s Astronomia Régulateur 43mm rose gold timepiece capabilities the aforementioned separate displays featuring hours, minutes and moments in three different postures on the dial, and a special new fine watchmaking activity.
Inspired from the Impossible”
Jacob & Co. has offered the régulateur a ground-breaking reinvention, taking a watchmaking typical and giving it a unique perspective. Thanks to its floating 3D structure, the movement has the capacity to complete a near-miraculous full turn in just 60 seconds. As the slimest Astronomia movement ever produced by Jacob & Co., Competence JCAM6 has an impressive overall of 552 components. high quality fake watches
The Astronomia Régulateur watch is flawlessly sized to sit on the actual wrist in a rose gold event with a diameter of 43 mm and a thickness associated with 18 mm. It is designed with the JCAM56 movement. This new watch is based on the Astronomia Revolution. The JCAM56 mobility rotates at a speed regarding 60 seconds and has three forearms, one of which is a flying tourbillon that rotates once a small. The other two arms are experts in the display of time, together with one subdial showing the particular minutes and printed using a fine scale, and the additional showing the hours.
For watchmakers as well as workers responsible for the requirements of their work, the just a few seconds indication is of utmost importance and also, in this case, the most distinctive feature. A slender and elegant golden palm emerges from the base in the vertical movement and take into account the seconds scale; a huge, domed, blue, translucent band. The ring itself revolves counterclockwise in a cycle involving 60 seconds, displaying the secs with unparalleled clarity.
replica Ulysse Nardin watches
Urwerk replica watches
replica luxury watches
best replica watches
Jacob & Co. introduced the stunning Astronomia Régulateur at Watches & Wonders 2024.
Technological Specifications:
The particular Astronomia
Movement:
Movement:
Calibre: JCAM56
Winding: Manual
Measurements: 38. 60 mm
Height: 13. 75 mm
Components: 552
Power Reserve: 48 hours
Frequency: 21'600 vph (3 Hz)
Functions: Straight rotating central platform: one minute clockwise
Rotating mere seconds subdial: 60 seconds per sequence 1 rotation counterclockwise for every second
Flying tourbillon: 1 rotation in 1 minute
Constant force unit with a loading frequency connected with 1/6 second
Off-centered, independent hour and tiny subdials with 2 differential devices
Case:
Height: 18 millimeter
Material: 18K rose gold colored and single sapphire scenario
Crystal: Curved anti-reflective sapphire crystal
Caseback: 18K rose gold
Water proofing: 30 meters (3 atmospheres)
Dial:
Base: Polished titanium
Subdials: Domed, blue polycarbonate with white printed level
Hands: 5N reddish gold dauphine hands
Strap and buckle:
Strap: Blue crocodile leather
Clasp: 18 CARAT rose gold folding buckle
Movement:
Movement:
Calibre: JCAM56
Winding: Manual
Height: 13. 75 mm
Components: 552
Case:
Dial:
Strap and buckle:
