How to predict yellow cards to win 100%?
reborn
To handle tense moments on the field, the image of a yellow card cannot be overlooked. Apart from over-under bets, Asian handicap bets, and European handicap bets, many enthusiasts also consider yellow card bets. Let's explore how to predict yellow cards in the article below with Wintips.
What is a yellow card in football?
In football, when a player commits an offense, we see a yellow card. But do you know what significance the yellow card holds? The yellow card is a warning used to caution a player who has violated certain rules. The referee is usually the one to present and decide to use the yellow card in a situation on the field. The yellow card is typically given to a player who commits a foul.
It acts as an explanation for that player's action to the audience watching the match. The referee can issue a yellow card to both players and coaching staff as long as they are part of the team. The team penalized with a yellow card will grant the opposing team a penalty kick. If a player receives 2 yellow cards, it equates to 1 red card and they are replaced by a substitute player.
Depending on the referee's decision, in many cases, a player will receive a warning, and only if they repeat the offense will they receive a yellow card. If they receive two yellow cards, it will turn into a red card, leading to dismissal from the field. Currently, not only football but many other sports also use yellow and red cards in competitions.
What are the rules for predicting yellow card bets?
The rules for predicting yellow card bets are calculated as follows:
Total cards: Players can bet on the total number of cards for one team or both teams in a match. Most bookmakers use Over 5.5 / Under 5.5, but this can vary between tournaments. They are based on the average number of yellow cards, which is usually around five.
Total booking points: based on a points system developed by the betting company. Points allocated for yellow cards can range from 1-3 depending on the betting company's system. The idea is to predict whether the total points will exceed the bookmaker's specified limit. For effective yellow card betting, you can access vip betting tips today to get the most accurate football tips.
First/Next/Last card: This involves predicting which team will receive the first card, the next card, or the last card in a match. It is most suitable for live betting, mainly for the "next" part of the bet that you can only place during the game.
Minute betting: This allows a player to bet on the minute they think a yellow card will be given to a team. The game time is 90 minutes divided into 9 parts of 10 minutes for players to place bets.
Simplest way to calculate yellow card bet points
A yellow card is worth 10 points, a red card is worth 25 points, and if a player is sent off due to two offenses, they will be rewarded 35 points instead of 45 as the second yellow card does not count for scoring purposes.
For example, in the image below, a bet placed between 0-20 points will result in a loss if there is a red card in the match. However, it allows a maximum of two warnings, as long as they are for different players.
Similarly, a bet placed between 21-40 points requires including from two to four yellow cards or one red card and a maximum of one cautious warning when sent off.
In the 2014 World Cup, an average of 2.92 yellow cards per game was received, with a total of 187 yellow cards, while 10 red cards were issued throughout the tournament, three of which were second yellow cards.
In the previous Premier League season, West Ham players had the worst disciplinary record, receiving the most penalties with 73 - along with 2 red cards - while Liverpool accumulated 44 yellow cards and one red card for the best performance.
Cách chơi kèo thẻ phạt và kinh nghiệm chơi - Click to view on Ko-fi - Ko-fi  ❤️ Where creators get support from fans through donations, memberships,  shop sales and more! The
Tips for Betting on Yellow Cards
Betting on yellow cards in football is not an easy task, whether you focus on placing point bets or the detailed options mentioned above. However, there are important factors or strategies to consider to rationalize the entire process, and you can engage with vip betting tips telegram channel to choose the easiest football bets to win. Some of these strategies include:
Check Statistical Data
One of the critical factors to consider when betting on football card markets is to examine the statistics of the teams playing. The good news is there are plenty of online resources with useful information you can use.
When placing bets, focus more on the team's card statistics. For instance: the average number of cards a club receives in a season. You should also check the number of cards a team has accumulated in their most recent matches. This will help you identify the precise card bets to place. This strategy can be applied even when dealing with the point betting market.
Referee for the Match
Though challenging, analyzing statistical data about the match referee can help you understand betting trends. This particularly applies if you're considering the point betting market. Some things to observe are the strictness of the referee.
You also need to note the frequency at which a specific referee issues cards. Finally, check the average number of cards a referee gives out in previous matches and use this knowledge to determine the expected total booking points in the match. You can also apply this data to place bets on other booking point markets.
Crucial Matches (Cup Finals, Decisive Ranking Matches, or other significant events)
Always take note of crucial matches when placing booking bets. Games like cup finals and decisive matches tend to trigger a competitive edge among players. This often impacts the number of cards issued in a match. So, before researching other aspects of the game, check the importance of the event. If two teams have faced each other in such a position before, review their history to get insights into how they typically perform.
Derbies and Matches with Intense Rivalry
Consider derby matches and games with intense rivalry. Such games often involve players and coaches with high spirits on both sides aiming for victory. Moreover, predicting internal clashes can be challenging; the outcomes are often unpredictable. A prime example of derby matches to note includes Liverpool vs Manchester United, Lazio vs Roma, and Celtic vs Rangers.
Teams' Playing Styles
Each team has a distinct playing style, often decided by their coach. The playing style determines the movements on the field and can influence the frequency of fouls in a match. Note that at football tips website , there's comprehensive information about football matches for newcomers.
Therefore, analyze the playing style of every team and identify similarities or differences in their gameplay that could lead to player confrontations. Teams' playing styles are crucial in football betting as they also affect the playing ability of both teams.
With this article, hopefully, you now have an idea of how to analyze yellow card bets. Wintips wishes you great success in your betting endeavors.
