Guide To Play Over/Under 3.5 Goals Bet in Football Betting
reborn
What is the Over/Under 3.5 goals bet? You often come across this bet but don't know how to place it to win? Let's find out about the Over/Under 3.5 goals bet in the following article with Wintips!
Win big with our expert golden soccer tips
Understanding the Over/Under 3.5 Goals Bet in Football Betting
The Over 3.5 goals bet means that you predict there will be more than three goals in a match.
For example, you are a fan of the Champions League and decide to bet on the match between Bayern Munich and Ajax Amsterdam. As a football enthusiast, you know that Bayern Munich is a team that scores a lot of goals, and Ajax also has a strong attacking line. You hope that this match will have over 3 goals. Therefore, the Over 3.5 goals bet is a reasonable choice.
If the match ends with a 3-1 victory for Bayern Munich, you will win the bet because the total number of goals scored in the match is 4, with Bayern scoring three goals and Ajax scoring one. On the other hand, both teams can also finish the match with a 3-3 draw. In this case, you still win the bet because the total number of goals scored is 6. However, if Bayern Munich ends the match with a 3-0 victory, it means you lose the bet because the number of goals scored in the match does not exceed three.
This Over 3.5 goals bet means that the match must have at least 4 goals or more for you to win the bet. This type of bet often offers high odds because matches with 4 or more goals are not frequent. Especially in highly competitive sports leagues and tournaments around the
world.
Explanation of the Under 3.5 Goals Bet in Football Betting
In the Under 3.5 goals bet, you predict that the total number of goals in the match will be less than 4. If you are familiar with football betting, you will understand that there can never be 3.5 goals. The purpose of the decimal number is to make the difference more specific when determining the number of goals scored. The number 3.5 means that the number of goals will not exceed 3. Therefore, you can only win the Under 3.5 goals bet when the total number of goals scored is 3 or less.
On the other hand, if the match ends with a 2-2 draw, you will lose the bet because the total number of goals scored is 4, which exceeds 3.5.
cầu thủ trên sân bóng
Use football tips site to win easily
Determining the Outcome of the Over/Under 3.5 Goals Bet
When the bookmaker offers the Over/Under 3.5 goals bet, if the player chooses Over (betting on the higher side) 3.5 goals:
The player wins if the match ends and the total number of goals scored is greater than or equal to 4 goals (e.g., scorelines like 2-2, 5-0, 3-1, etc.).
The player loses if the match ends and the total number of goals scored is less than or equal to 3 goals (e.g., scorelines like 0-0, 1-0, 2-0, etc.).
In the case of the bookmaker offering the Over/Under 3.5 goals bet and the player chooses Under (betting on the lower side) 3.5 goals:
The player wins if the match ends with a total number of goals scored that is less than or equal to 3 goals.
The player loses if the match ends with a total number of goals scored that is greater than or equal to 4 goals.
Pocketing Key Points about Over/Under 3.5 Goals Bet
One important thing to note is that these bets are effective within 90 minutes. Therefore, the number of goals is determined by calculations after the final whistle, including stoppage time. Any goals scored outside the full-time period or in extra time are not counted.
The total number of goals is combined from both teams. However, this does not mean that both teams have to score or not score for you to win the bet. As long as the total number of goals meets the chosen option of the bet, you will win.
Some Tips when Betting on Over/Under 3.5 Goals
Like any other bet, it is important to know how to analyze and understand each team. You must choose the right time to enter the bet, not being too eager or missing opportunities due to fear.
If the Over 3.5 goals bet starts with a high odds range but the payout ratio is low, such as 0.80 to 0.88, don't rush into the bet. Wait for the match to be played for 3-5 minutes, by which time the odds will rise to 0.92 to 0.95 or higher, then place your bet.
If you haven't entered the bet from the beginning and there is an early goal, remain calm and wait. Don't jump into the bet right after the goal; instead, wait for the odds to stabilize before starting to bet.
If the Over/Under odds increase compared to the initial odds, it means both teams are playing very offensively. The bookmaker is afraid of an over result, so they increase the Over/Under odds. In this case, you need to observe the match's progress before making a decision.
View more articles : what is asian handicap in soccer betting
So, the Over 3.5 goals and Under 3.5 goals bets are easy to determine whether you win or lose. However, the most important thing is to have experience in choosing the right timing to place the bet. Hopefully, this analysis will help many players understand what Over/Under 3.5 goals bet is all about. Good luck!
