The handicap 4 4.5 is a type of handicap commonly found in the betting boards of reputable bookmakers. Players have to predict whether the total number of goals scored in the match will be higher or lower than 4.25.
Certainly, not all players know exactly what the handicap 4 4.5 is. Alongside the 4 1/4 handicap, the 4 4.5 handicap is being applied by most major bookmakers. With this type of betting, bettors only need online football tips to focus on the number of goals scored at the end of the match. The result of the win or loss is not too important.
What is the handicap 4 4.5?
The handicap 4 4.5 is present on the betting boards of most professional bookmakers such as when accessing bookmakers' websites. Similar to other types of handicaps, participants placing bets on the 4 4.5 handicap need to predict the number of goals scored at the end of the match and choose either over or under.
Specifically, bettors must predict whether, when the match ends, the number of goals scored will be more or less than 4.25 goals. In which, the "over" option corresponds to the number of goals scored over 4.25 goals. Meanwhile, the "under" option corresponds to the number of goals scored under 4.5 goals.
In general, instead of focusing on the result of winning or losing, players only need to pay attention to the number of goals scored at the end of the match. Then, the bettor will choose either over or under.
Guide to calculating the handicap 4 4.5
Similar to how to understand the handicap 1, calculating the handicap 4 4.5 is not too complicated. If you don't know how to calculate it specifically, you can refer to the detailed instructions below.
The match ends with 5 goals or more: Players win if they choose over. If they choose under, the bettor will lose.
The match ends with 4 goals: Players lose half of the bet if they choose over. Conversely, if they choose under, they will win half of the bet.
The match ends with 3 goals: Players lose if they choose over. If they choose under, they will win.
When calculating the winning bet, you only need to multiply the initial bet amount by the payout ratio. Therefore, besides the profit, players can also recover the original bet amount.
Find out more : football tips telegram
03 Notes when playing over/under 4 4.5
During the process of betting on the over/under market, players must spend time understanding the correlation between the two teams, choosing suitable betting options, and balancing their capital.
1. Understanding the correlation between the two teams
Although there is no need to focus on the outcome of winning or losing, players still need to update the situation of both teams through the following aspects:
Squad situation: Evaluate the recent form of each team, potential game-changing factors, and tactics that both teams might apply.
Head-to-head history between the two teams: The team that has won more matches is often considered superior. However, when analyzing the head-to-head history, players should consider the performance in the last 5 or 10 matches.
Predicting the starting lineup: The starting lineup of each team is usually announced a few minutes before the match. However, players should predict beforehand which key players might participate in the match.
2. Considering the over option
For the over/under 4 4.5 market, bettors do not need to worry about the result of winning or losing. However, predicting whether there will be more or fewer than 4.5 goals is not easy. According to the experience of most players, the over option often holds the advantage in matches within the framework of national tournaments.
However, this experience is still only for reference. Because every actual match is always difficult to predict. Therefore, in the process of choosing a betting option, players need to combine specific analysis and regularly update news related to the match.
3. Distributing bets reasonably
Sports betting, in particular, and betting in general, always carry associated risks. Therefore, players need to pay special attention to distributing their bets reasonably. In every situation, bettors should not risk all their capital on a single match.
Instead, players should divide their capital into smaller portions and place scattered bets. In case of losing three consecutive matches, consider stopping playing and avoid attempting to recover losses.
From all the shared information betting tips best sites in this article, you can accurately understand what over/under 4 4.5 means. Although there is no need to focus on the outcome of winning or losing, players should still choose betting options wisely and balance their capital scientifically.
