What is Asian Handicap in football? To delve into this type of bet, let's explore the details below. Wintips also shares valuable insights and strategies for playing Asian Handicap bets, especially beneficial for newcomers.
What does Asian Handicap entail in football?
In football, Asian Handicap betting is also known as a Draw No Bet. This type of bet is a variation of the Asian handicap displayed on various online betting boards. Essentially, this type of betting emerges when two teams play on an even playing field, displaying similar strengths.
The match will have a handicap of 0 or a negligible low handicap. Typically, it appears in tournaments of various sizes. This type of bet signifies the fairness between the two competing teams, which is appreciated by betting enthusiasts.
What are the variations of Asian Handicap bets?
Presently, on betting boards across various platforms, there are two enticing variations that attract numerous players. Here's a detailed sure soccer tips to analysis of these two variations:
Asian Handicap 0:
This is a traditional type of bet with a handicap of 0. It's applied when two teams are evenly matched in terms of strength. Players can bet on either Team A or Team B. Here are the potential outcomes:
Betting on Team A/B: If Team A/B wins with any score, you win the entire bet. If Team A/B loses, you lose the entire bet.
If the match ends in a draw after betting on Team A/B, the initial bet amount is returned.
Asian Handicap 0.25:
This is a newer variation of the traditional bet but has been present for a while on betting boards. The handicap in this bet is 0.25, providing a noticeable difference from the Asian Handicap 0.
In an upcoming football match, the bookmaker will provide odds between two teams that have significant differences in strength. Consequently, the stronger team will give a 0.25 goal advantage to the weaker team to ensure fairness.
There are scenarios that can unfold in this type of bet:
The stronger team wins by a margin of at least 1 goal: If a bettor placed their wager on the stronger team, they win the full amount. If they bet on the weaker team, they lose the entire wager.
The weaker team wins by a margin of at least 1 goal: A bettor who placed their wager on the weaker team wins the entire amount, while the one who bet on the stronger team loses the entire wager.
Full-time score results in a draw: A bettor who wagered on the stronger team loses half the amount, while the one who bet on the weaker team wins half the amount.
These variations in Asian Handicap betting offer different strategies and possibilities for bettors seeking diverse options.
Formula for Calculating Winnings in Handicap Betting
In handicap betting, the calculation of winning money is based on the outcome of the match. Specifically, the following cases can occur:
Team on top wins:
If you bet on the top team, the winning money is calculated by the formula: Winning money = Bet amount x odds provided by the bookmaker.
If you bet on the other team, you lose the entire amount wagered.
Match ends in a draw:
If you bet on either the top or bottom team and the result ends in a draw, the bookmaker refunds the bet amount.
Team at the bottom wins:
If you bet on the top team, you lose the entire bet amount.
If you bet on the bottom team, your winnings are calculated using the formula: Winning money = Bet amount x odds given.
Use betting tips app to win easily : soccer tips sites
Guide to Playing and Betting on Handicap Betting at the Bookmaker:
In general, the bookmaker is creating convenient conditions for football betting enthusiasts to experience high-quality betting rooms.
Currently, you can participate in betting on football matches with simple handicap betting in 4 steps:
Step 1: Log in to your official account at the bookmaker after successful registration.
Step 2: Choose Deposit with various flexible methods to have funds in your account.
Step 3: Enter the sports room and select football betting.
Step 4: Choose handicap betting in the tournament or match you like, then enter the bet amount and confirm.
Step 5: Receive rewards in your pocket after the results are announced within 24 hours by the bookmaker.
Additionally, for handicap betting and football matches at the bookmaker, there are special offers. You simply need to participate to receive impressive rewards when accessing the gaming portal.
Some Lessons for Newcomers Playing Handicap Betting:
To consistently have a winning ratio against the bookmaker, everyone participating needs used football tips app research and understand handicap betting. Below are some lessons that professional players have summarized, which newcomers can learn from and apply:
For handicap betting when the bookmaker's odds are under 2.25 and the home team tends to receive heavy bets, you can bet on the away team for higher winning odds.
Choose to bet on the home team when the away team is receiving heavy bets and the over/under odds are low.
In cases where the home team is rated lower but has stable performance, consider betting on the home team.
If the over/under odds are 2.75, consider betting on the team with lower winning odds when the match is nearing or has just started.
With this information about handicap betting, it's hoped that even newcomers can achieve the most favorable betting results. Quickly join the reputable football betting platform to bet on your favorite team!
Asian Handicap 0:
Team on top wins:
