When following a match, you can use the 1×2 betting to place your bets based on your predictions. However, not everyone can fully understand and calculate the odds for this type of betting. If you are new to this field, read the following article to gain a better understanding of how to calculate and read the 1×2 betting odds.
This article will help you understand the basic concepts of 1×2 betting.
Watch now: asian handicap soccer betting tips to play football betting always win
What is 1×2 Betting?
1×2 betting, also known as the "match result" or "win-draw-win" betting, represents the three possible outcomes of a match. "1" Represents the win for the home team, "x" represents a draw, and "2" represents the win for the away team.
In this type of betting, you only need to focus on which team will win, draw, or lose, without considering the total goals like in over/under betting, or the margin of victory like in handicap betting.
Placing a bet on the home team (Home Team): If the home team wins, you win the bet.
Placing a bet on the away team (Away Team): If the away team wins, you win the bet.
Placing a bet on a draw (Draw): If the match ends in a draw, you win the bet.
Some basic terms in 1×2 betting:
European football odds have two corresponding types of bets, including: 1st half (1H) and full-time (FT), which are abbreviated as follows:
1H.1×2: This abbreviation stands for "Half 1×2," indicating a bet on the 1×2 outcome of the first half.
FT.1×2: This abbreviation stands for "Full-Time 1×2," indicating a bet on the 1×2 outcome of the entire match.
The corresponding abbreviations for the odds in European football betting are explained as follows:
1: Represents the home team. Players betting on this option will win their bets if the home team wins.
X: Represents a draw. Players betting on a draw will win their bets if the final result is a draw.
2: Represents the away team. Players betting on the away team will win their bets if the away team wins.
Calculating the winnings for 1×2 betting:
To calculate the winnings, you can follow these two steps:
Step 1: Calculate the profit without commission for the bookmaker using the formula:
Profit = Odds x Bet amount
Step 2: Calculate the profit including the commission percentage:
[Bet amount x (Odds - 1)] x Commission percentage
Find out more : what is asian handicap
Effective 1×2 Betting Tips
Compared to other types of bets, 1×2 betting has simple and understandable characteristics that make it easier for players to win. To learn about effective strategies for playing 1×2 bets, follow the tips below:
Understand the rules:
A key tip for analyzing 1×2 bets is for players to understand the rules of reading odds and the 1×2 and handicap odds. Consider and choose bets with lower odds.
However, the best approach to winning is to avoid choosing matches that are evenly balanced, as the outcome may not be favorable for the player.
Research before placing bets:
Without researching information about the two teams before placing 1×2 bets, the chances of winning will be very low. The form of a team has a significant impact on the players' mentality during the game. It is difficult to win with teams in a crisis situation.
Therefore, when playing 1×2 bets, you need to have a solid understanding of team information to make informed and effective decisions.
Monitor match fluctuations:
For 1×2 bets, the odds are not always fixed. The 1×2 odds are often adjusted by bookmakers 2-3 days before the match starts. Therefore, players must be cautious when betting on 1×2. Online betting on 1×2 requires players to be extremely careful to optimize their bets.
Players should check the odds table and choose reputable bookmakers to ensure professional football betting. Regularly check the odds to determine the most suitable betting method. If you feel unsure about your bet, you can change the odds or choose handicap or over/under betting.
Choose half bets to minimize risks:
It is recommended to choose half bets in order to minimize risks.
What is a football tip? See now : betting tips sites
In summary, Wintips has compiled some information about 1×2 betting and effective betting strategies to help players increase their winning rate up to 90%. We hope that bettors have grasped the basic tips to achieve the highest profits!
